I have a Haywood color logic light under my diving board that when I turn it on thru the color logic switch it turns on as I would expect ( switch goes thru it’s setup) and light turns on but it will not stay on one color cycles thru all options on the bulb and doesn’t stop. Replaced switch still doing it - is there any type of factory reset I can do on switch to fix or do I need to replace the complete light
Can you put it on a regular-style on/off wall switch? That would tell you if the issue is the controller or the light.
If you want to try to reset it, here is the Hayward ColorLogic Troubleshooting guide - if that does not help you can always try Hayward’s technical assistance line at (908) 355-7995. Unfortunately, there are no serviceable parts in these so replacing the fixture is the only option if the light is bad.
On the Colorlogic lights, the first program is called Voodoo Lounge which is a show that cycles through all the colors. This by default is where the lights will start after powering up with a white light. The next one (program 2) should be blue. You just need to advance to the next program. There are a total of 10 colors and 7 shows.
Hope this helps.
I replaced the color logic switch already that didn’t Help.
I have tried each color on two different switches
I was hoping there was some type or reset I could do on the color logic light it self thru the switch but doesn’t appear to be
