I have what looks like a Hayward Vari-Flo SP71 multi valve (pics attached). I’m guess it is really old.
It is leaking around the handle, so I’m looking for likely a gasket and O rings. I am find almost nothing for this valve. Does anyone know if there is another model number I should be using to lookup? Is there something else that is the same or compatible?
Thanks!
Good afternoon, the Hayward Vari-Flo SP71 refers to the SP-71 Series, which includes the SP-710, SP-711, and SP-712 models. These will be the gaskets/o-rings and spring for the SP-71 Series valve:
- Spider gasket - SPX0710XD
- Cover O-ring - SPX0710XZ3
- Valve stem O-ring with Teflon seal - SPX0735GA
- Spring - SPX0603S
- Spring washers - SPX0710Z62
We also have the Key Cover and Handle Assembly: SPX0710XBA17
You would need to get the Spider gasket as well as it does not come included.
Thank you for the quick and thorough reply!
