MY HAYWARD SUPER PUMP NEEDS REPLACING. CAN YOU TELL ME THE CORRECT REPLACEMENT? I HAVE 1-1/2 HP MODEL c48l2n134b1 .
Hello Markzipp - If you need the complete pump, the Super Pump model is SP2610X15. If you need the motor only, the model number is UST1152. We would also recommend replacing the seals if you replace the motor. The seal kit for a standard chlorine pool is GOKIT3 and the kit for salt water is GOKIT3SALT.
