which ee pump could i replace my ust1102 c48k2n143c1c with. my pump still works fine but am concerned about energy bill.
Hello Ed - If you’re looking for the most energy efficient replacement motor, you’d want to go with a variable speed version. The variable speed motor for your Super Pump would be part number ECM16CU. This is a 1.65 total HP motor. Keep in mind that this motor will only run on 230v.
We also recommend replacing the seals when you replace the motor. The seal kit is GOKIT3. If you have salt water, go with GOKIT3SALT.
i am running 230v. if i didn’t want to go the variable speed version is there an ee motor you would suggest instead
The EE single speed motor would be model UCT1102.
thanks Rob
You’re welcome. Thank you for shopping with INYOpools.com!
