I have a Hayward super pump 1.5 hp variable speed pump 230v that need the bearings replaced in the motor from a seal failure. Is the bearing replacement in these variable speed motors the same as your how to video on the super pump replacement? Thanks in advance.
Hello Jacob - We do not have a parts breakdown for that motor. I’m not sure what bearings are used. The bearing replacement would be similar to a standard Super Pump. However, there are very strong magnets used in the variable speed motors that make the bearing replacement a little more difficult.
