Hayward Super Pump bearings (which bearings?)
Hello,
I have a Hayward Super Pump 700, 1.5 hp (SP2670010X15) and the bearings have failed. It’s less than 2 years old. What are the correct bearings for replacing?
Thanks in advance,
Hooyah
I have same pump, problem, and question.
I’m here a year later looking for the same answer. I guess you didn’t get one?
Greetings to all, and sorry for the late reply!  Due to the strength of the magnets used, we do not recommend bearing replacement in a variable-speed motor on your Hayward Super Pump VS 700 unless it is done by a qualified motor repair facility.  They are very difficult to work with unless you have the proper equipment, and we want you to keep all of your fingers!
