Hi, I have a Hayward gold line aqua rite salt chlorine generator that is 2 years old. It recently quit working so I took it apart and I saw some debris in it and I cleaned it and put it back together. It worked for about a week and I just realized it stopped working again. I removed it and it is clean. I removed the flow switch and it seems fine also. When I power it up it flashes no flow for about 45 seconds then it stops and the generating light illumininates for 10 seconds then goes out. The power light or any other light comes on, any suggestions on how to get it to generate
Hi Eric99,
I would the troubleshooting sequence in this AquaRite Troubleshooting Guide. This is not the normal pointless troubleshooting guide as it goes pretty in depth. The item we see go bad the most is the main PCB board and we carry an AfterMarket AquaRite PCB Board which will most likely fix your issue.
