Every day I need to recalibrate the system. The water tested at at 3100 and works fine but after the pump runs for a period of time the Check salt and inspect cell lights are on. I replaced the cell with a new one (t-9) and it does the same thing. I know the salt is right and the cell is good but the system will not hold the recalibration setting.
Hi Richard, this is usually a sign that the salt cell size is not set correctly. Be sure the salt system is set for the correct-sized salt cell, and also be sure you received what you ordered (the T-9 salt cell).
We also recommend not trusting the display on your salt system for the salt content of your pool since they are often incorrect. Be sure to get a salt test kit for accuracy.
