On power up motor is louder than usual; shaft and impeller seem to spin, but motor cuts off after several seconds. Internal motor circuit breaker (CB) trips and motor will shut off temporarily (sometimes control panel CB will trip). Input wiring is
Green → (GRD);
Red → A (LO);
Black → L1 (HI);
White → L2 (COM);
On power up, HI = 155vac, LO = 232vac; when internal trip takes place, both jump to 240vac. Start capacitor measures good. I have primed the pump (filled with water etc). I can turn the impeller, and the shaft turns when I do so. Any ideas?
The pump is the 2 speed Hayward SP3220Z2BE
It sounds like you might have a bad phase winding. When the windings go, it’s time to replace the motor. The direct replacement motor would be part number SPX3220Z2BER.
Long time past, but I did end up buying the B2984 from INYO back in 2019, and all went well. I just ordered the exact motor again, since this weekend I noticed the noise from the pump has increased drastically. Still seems to work fine, but very noisy. After replacing, I will likely save the old motor, purchase a new pair of bearings, and attempt to replace (to keep as a spare).
