Hayward pool pump motor SP1607-Z-2-MSC making noise
My super pump is starting to make a lot of noise. What would you recommend replacing the pump with with the above model number or could I get it rebuilt?
Hi Jayman,
I would suggest just replacing the motor on your pump as typically the noise you describe is the bearings going bad in your motor and just your motor would need to be replaced and not you entire pump. The motor you would need is the STS1102 Replacement Motor along with a Hayward Super Tune Up Kit.
