I have replaced everything in the Hayward Navigator all parts are new except for the cone gear it’s sticks to the wall does not want to turn away I’ve even replace the hose that connects to the cone gear as well with a new Hayward hose I have no idea what’s going on and I just need to fix it I’ve almost spent as much fixing it as I could have bought a new one for just drive me nuts should I buy a new cone gear or just give up and buy something else thank you for your time
It’s possible that some small debris has got stuck in the gear box. Take the gear box out and blow into the hole in the corner. You should hear the gears spinning. If they do not spin, take the individual gears out and wash them off.
The gears spin freely and new gearbox as well
Thank you for the input
Do the small gears in the gear box spin freely or are you referring to the cone gear spinning at the top?
Gears in box spinning freely
Cone gear turns only back and forth once then seems to lock up
New bushing on cone gear also
I can’t see any wear on gear like teeth worn down
Thank you
You mentioned the fact that you have replaced everything. Did that include a Medium Turbine / Spindle Gear Kit? Usually, one of those gears would fail before the cone gear. If you’ve replaced those parts, the only other part we’d recommend replacing is the cone gear.
Yes That was replace also
Only thing left is the cone gear to be replaced
Ok Thanks
I will give that a try
