Hayward In-Ground Pool Replacement pump suggestion request
Hayward Super Pump Series (ISSP Series) information Tag from in-ground pool pump motor with gold colored casing… 60 cycle single phase. Apart of pump and housing series Modle SP2607X10 inlcluding 21 parts including knobs, basket, strainer, housing, diffuser gasket, diffuser, impellor, seal assembly, housing gasket, seal plate, motor mounting plate, mounting foot, screw sets, mounting foot adapter, slinger, and motor. (motor will not start, could be start or run capacitor issue but not sure) Motor is run once it starts, but starting is diffcult due to heat switch kick off. Motor installed in May 2013 (38 months of contiunous operation).
Need correct InYoPool replament motor link or part number for order and proper seal kit for replacment motor as well as any parts required for proper matchup of replacement motor to other current parts which will continue to be used.
Motot Details (see attached image for pump motor tag information)
MFG: CENTURY, TIPP CITY, OHIO 45371
Model # C48K2N143B1
Ser: 26312FM
(Other P/N or M/N listed on tag SPX1607Z1M)
1HP
KW: .75
RPM: 3450
VOLTS: 115/230
AMPS: 15.0/7.5
HZ: 60
SF: 1.1
FR: 56J
PH:1
AUTO E
AMB: 50 ^C
TYPE: UAC
DUTY: CONT
CODE: J
UNSUL CLASS: B
SP1607Z1M
Need very quick turnaround information on proper replacment pump and seal kit etc. to purchase. Looking to purchase ASAP to be 2 day express shipped to my address.
Brannon J. Burleson
1065 Tennessee Street
Hackleburg, AL 35564
205-412-6655
Hi Brannon,
Thank you for all the detailed information. You will need the UST1102 1 HP Replacement Motor and the Hayward Super Pump Tune Up Kit. Our standard Free shipping is 3 business days and 2 day air shipping is available for $55. If you purchase before 11 AM on Monday the standard shipping would have the order to you by Thursday and the 2 Day shipping would have the order to you by Wednesday. You will be able to select your shipping options during checkout.
