Hayward Colorlogic light replacement
My 13 year old Hayward Colorlogic light finally failed. The model number was SPO525SLED100.  What is the less expensive option you recommend?. Still want LED colors. Of interest it is controlled by a Pentair control box. We had no problem changing the colors by cycling the on off button which wasn’t a big deal to us. I can’t find the same replacement bulb number. Appreciate any suggestions.
Hi DNick53,
I would suggest this Color Splash 120V 100’ Pool Light Color Changing LED this light is in stock but please note the cord length is 50’, not sure if that is long enough for you? I like this light as if the bulb ever goes bad it is replaceable, unlike the colorlogic where if the bulb goes bad then the entire fixture needs to be replaced. This light is LED Color changing and would operate through your Pentair Control box the same way your color logic did. I hope this helps!
