Hayward colorlogic 4.0 troubleshooting
I have an SP0535SLED50 spa light that started acting weird a few months ago, now not working at all. At first it would only display a few colors, not the 16 presets it should. I then installed a Hayward AQL-COLOR-MODHV to add colors control buttons to my panel (aqua-plus-16). That worked fine and I could program a few additional colors, though not very bright. After 3 weeks, pool pump stopped working as main circuit fuse would always trip. i found that disconnecting the aql-color-modhv from main control board solved the problem, thinking the aql-color-modhv was bad, and quickly got main pump working again. After a few more weeks I went in to troubleshoot. Plugged the aql-color-modhv again and the breaker no longer trips, however the spa light does not work at all. When I go into Config to search for lights, it only finds my 3 pool lights, no longer see’s the 4th light in spa.
So is my spa light dead and needs replacement, like $900, or is there a potential repair / fix for this?
Thanks in advance!
We are sorry to hear about that. Check the electrical connections to be sure there are no issues there and, if they are fine, replacing it is your only option. We are not aware of any user-serviceable parts in the ColorLogic lights.
I think these have a 3-year warranty, so check that out before you spring for a new light.
