Hayward Color Logic light shuts off
HI, I have an in-ground pool with Hayward ColorLogic light that recently stopped working. The light comes on in test mode - white light, then as it is about to change to the color it just shuts off. There is a clicking sound from the panel when the light turns on, but no sounds when it turns off, so it is not the controller, which leaves the transformer . The breaker doesn’t flip either. In fact, even after the light shits off, I can still see what looks like a dim light strip. Any suggestions on what I can test before I start spending $? Thank you.
It sounds like the issue could be with the transformer, wiring, or the fixture itself. Start by checking all your connections. Then, test the transformer to make sure it’s getting the correct voltage. While doing that, look for any signs of damage or overheating. If everything checks out and the problem persists, you may need to replace the fixture or contact a professional for further help.
