Flow rates for V Green 165
Thinking of replacing a single speed pump that is squeeling with a new variable speed pump but trying to calculate how low a speed I can run it on to circulate the pool water 1x in 24 hours or less. How do I find the flow rates for the V Green 165?
There isn’t a flow rate chart available for the V-Green 165 motor because it is used on several different pumps. We’d recommend installing a pool flowmeter on your plumbing. That way you can determine the exact flow rate at each speed.
