Flexible schedule 40 pvc
Hi Guys,
what are your thoughts on flexible schedule 40 pvc? Sounds like a dream having way less fittings and gentler curves to maximize flow. Are there any downsides!
thanks
Frank
Frankie - We would recommend rigid pvc if you’re planning to run the pipe underground. The rigid pvc is impervious to roots and other objects underneath the surface. If the pipe will be above ground, the flexible pvc is a great option.
