As I look for a replacement filter for my waterway system, the only cartridge that is close in size is only 2" off in length. My current cartridge is 23", the filter that is sold is 25" in length, all other measurements are the same as what I have. Is the 2" going to make a difference?
Hi Rachel,
Could you please grab the model # off of your filter which should be located on a label on the side of the filter tank? Or could you send us a few photos of your filter? A close up of the label on the filter and a wide shot of the filter? Also there should be a part # embossed into the plastic end cap of the cartridge could you supply this as well? Once we get this information we will be able to suggest the proper replacement cartridge.
