Rotating Discharge Port on Spa Pump
The hot tub I am working on has the tub water exit on the top instead of on the side, is there a way to turn the tub exit to the top or should I have gotten a pump with the exit on top?
Yes, you can rotate the discharge port on a spa pump. Check out the following guide from Step 7 through Step 22.
https://www.inyopools.com/HowToPage/how-to-rotate-the-discharge-port-on-a-pureline-pure-pro-xl-pump.aspx
