Dreaded No Power light and no Generating light
Hi all!
So, I’ve been reading avidly, as I just bought a home with a pool.  The pool has a Hayward Aquarite Salt generator, and we’ve been having a hard time maintaining Chlorine levels.
I started looking at it, and realized that the power and generating LEDs aren’t lit up, but the No Flow LED lights up when my pump is off, and I have LCD display data.
So, I followed the steps in the how-to and the Diag manual:
https://www.inyopools.com/HowToPage/how-to-read-and-adjust-the-hayward-aqua-rite-scg-operational-values.aspx
https://images.inyopools.com/cloud/documents/aquarite-troubleshooting-guide.pdf
What I’m finding is that I have the correct input power (240v), the yellow cables show correct voltage, the red/black cables show the right DC voltage, the transformer has the right impedence, and the fuse is good.
What’s odd is that when I test the DSP board pins, I don’t have any voltage at all between pin 1 and 3, but the board still has power, since the LCD display and diagnostics button work.
Also odd, is that the instant salt display value is 0.00.  I was thinking that this might prevent it from generating (assuming there’s no salt in the water for it to process), but then I read that the instant reading requires it to generate before it will read a new value.
Incidentally, I’ve inspected the salt cell, and it looks brand new.  No buildup of any kind.
The conclusion I’m drawing is that I need a new PCB, and that the instant salt reading will correct after that.
Is that a sound conclusion?
Thanks in advance!!
Did you ever fix your Hayward Aqualite as mine is brand new same issue No Led
