Drain pipe doesn't drain
I have an above ground pool which has a problem with the drain pipe. It doesn’t have water draining out of it and to the pump that pumps it into the sand filter. What can I do about it?
RobertDay - Is there a valve at the port of the skimmer/suction line? Maybe this is closed and that is why water is not getting to the pump. Also, make sure there is not a clog in that line. You can use an electricians fish tape to snake it through the line and clear any clogs.
