drain pipe
Hi
i just moved into this place with pool and not sure what are these pipes and valves assciated with them. the picture that is posted is when the muliport valve is in filter position.
Mine is Hayward Pro Grid DE filter.
can some one help me so that i can label them. Also appreciate if you let me know what would be the position of the valves when i run the below …
  • waste/drain
  • backwash
  • rinse
thanks
ayward pro grid DE filter.
Thank you for contacting Inyo. When it comes to plumbing and valves, every pool is different. We can’t say for sure which pipe leads to what or how the valve should be set. You’ll have to test each one and then label them.
In the picture below, I’ve identified what those lines and valves could be controlling.
Check out our article titled “What Does My Valve Control?”.
The backwash valve that controls the filter is not in the picture you provided. That valve should be connected to the Hayward ProGrid filter.
thanks for the details. appreciate.
You’re welcome. Good luck!
