Dolphin Pro Cable Replacement
The cable on my Maytronics Dolphin Pro was recently destroyed. The cable had a black and a white wire. It connected to the “old style” power supply with a four pronged plug. I purchased a replacement cable 9995861-ASSY and the 3259-325retrofit kit based on the Q&A section saying that it would work with the Dolphin Pro.
I notice that the 9995861-ASSYcable only has a two prong plug. Before I spend time building the plug on the machine side, I wanted to make sure this cable would work with my existing power supply.
Hello WillyB - Thank you for contacting Inyo. What is the serial number of your cleaner? This number will be located on the inside of the cleaner. What is the part number on the power supply?
The power supply is 9995658, type “Basic Diagnostic DC”. The robot is 101663JA96.
We’ve contacted Maytronics to confirm if the parts you ordered will work. We’ll reply back as soon as we get a response.
Thank you.
