I have a 6 way Jacuzzi Dvk-6 valve and Aquamax 225 filter that is draining when in the filter position.
The local pool store said it needs a new diverter and found the repair kit on inyopools.com.
Can you confirm that it is indeed a Jacuzzi Dvk-6 valve (see pictures below) and if the DIVERTER REPAIR KIT DV6/7 (39251509RKIT) will fit that valve.Does that kit come with instructions as I have never replaced one before.
Hi StephenL,
Yes you have the Jacuzzi DVK6 Valve and you will require this Jacuzzi DVK6 Valve Cover Repair Kit the kit does not come with instructions but you can follow steps 1-3 of our Guide on How to Replace a Spider Gasket you would stop at step 3 and then put the new handle assembly in. It is pretty easy and if you run into any problems then please give us a call at 407-834-2200 and any of our customer service reps. can give you a hand with the install.
