Dive board?
Can you tell me which diving board I need to order?   I have salt water system,   I need pewter gray color, and I will be installing it on top of existing concrete that never has had a diving board.  I was not sure which type to order.  I would like the 6 foot board. Thanks
Hi Christy,
Thank you for the post about your diving board. You would need this 6’ Salt Diving Board System in Pewter Gray Since this is an exsisting deck you will need this Diving Board Epox Kit
Below is an explanation of how the Epoxy kit works…
Our Diving Board Epoxy Kits are ideal for installation of a diving board on existing pool decks. Most of Our customers use this product for either one of the two scenarios.First, if you have an older diving board which you are replacing and you cannot find a base to match the bolts which are sticking up out of your deck. In this scenario, you would purchase any new diving board and base combination that we offer. You would then purchase an epoxy kit and cut the existing bolts sticking up from your deck flush to your deck. Following this, you will use a core drill to drill a hole in your deck in the proper position to match your new base. After drilling the holes you would apply the epoxy to your bolts and place the bolts into the holes you have drilled. You will now have the appropriate bolts sticking up out of your deck and the new base would slide over the bolts, you would then use the hardware which comes with the base to attach the base to the bolts. Many of our customers also use this kit for existing pool decks which have never had a diving board installed. You would follow the same steps as outlined above for this scenario as well.
