DE Filter Leak
My Hayward DO filter O-ring seal is leaking at the two bolts connections.  I’ve removed and cleaned the O-ring and cleaned the sealing surfaces.  Replaced the o-ring in a different spot.  Seal still leaks under each bolt on the clamp ring?
Any ideas?  “Stretched” clamp
