DE Filter Grids
I have an old   (1997 )  American Products Titan , Vertical Grid DE Filter.
I can not read any other info on the filter except for it is 36" in Dia and 43" vertical, with 50 psi.
My Pool is in ground 16’ x 32’, About 25,000 gal.
The DE Grids need to be replaced.
Can you suggest A part Number to order ?
I want to get A complete new Grid unit with the Plastic holders
Hi MLKK1073,
Thanks for the information… To ensure you get the proper DE Grid assembly I would need for you to remove of the DE grids and measure the length of one of the DE grids. Also can you let me know if the filter tank is stainless steel or fiberglass? Once I get these two pieces of information then I can suggest the proper DE Grid Assembly replacement for your filter. Thanks so much.
From MLKK1073
Sorry for the delayed ,
The Tank is Fiberglass and the inside diameter is 20." The grids are  18 " High Also I should replace the plastic , top and bottom holders . Thanks for your help
Hi Leonard,
Could you let us know if your filter looks like this American Products Titan CM Filter or this American Products Titan RPM Filter or do you see any reference to CM or RPM on the filter?
From MLKK1073
It is an American Products  TiTan  RPM
Hi Leonard,
Thanks that helps out a bunch! You will need the 59023500 DE Grid Assembly for the 36 Sq. Ft. American Products Titan RPM Filter we have this DE grid assembly in stock ready to ship. This is the complete pre-assembled grid assembly which includes the top and bottom manifold (plastic holders), rods, DE grids and breather tube. Getting the complete assembly is much easier to install then going with the individual grids as the individual grids can be confusing on how they go into the filter.
