I’m trying to find a replacement for my Hayward inground pool strainer basket housing. Apparently the housing has cracked and is now leaking. We thiught it was the oring top lid but it’s not. It looks like there is a small crack in the housing where the water from the pool feeds into the strainer. It leaks when off but not when on. I have model SP3200Z13. I’m hoping it’s still sold and if not there’s a another Hayward model that will work so that I don’t have to reroute my pvc pipes.
Thank you for contacting Inyo. That number did not bring up a match in our system. Could you post a picture of the pump?
It looks like you have a Hayward Super II. The strainer housing with 1.5" ports is part number 5110-071. The strainer housing with 2" ports is part number 5110-072.
Thank you- one last question- how do I know which to get?
Krystal
You’d get the one that matches your plumbing size. Look on the PVC and see if it says 1.5" or 2" somewhere on the pipe or fittings.
Thank you!
You’re welcome. Good luck!
