Recently my pool has been losing a ton of water. I had leak repair folks come out and they pulled the light apart and apparently there is a crack in the housing(not sure if that is the right term). He filled it with apoxi and said he hopes that it will hold.
Days later it began leaking again. I went to a local pool store that does repairs and asked for a quote to fix it. They said that they couldnt and I would need a pool builder to do it and it could run 2000-2500 dollars.
Does this sound right? Can I drain the pool to the bottom of the light, pull the light and use a cement to seal the crack?
Any advice would be greatly appreciated. Thank you in advance.
I do have a video that the leak locator made while trying to repair it if that could help get an idea of my problem.
-Dan
