I need to replace a cracked check valve. The cracked check valve I need to replace is a Jandy P/N 7236 REV, 2 inch plumbing, and I have a 1.5HP pool filter motor. Also, what plumbing cement is recommended between the valve and the schedule 40 PVC? Below are pictures:
The replacement check valve is part number 25830-714-000. Click Here to View the Check Valve
Medium grade pvc cement will work well.
