Control panel for Aquacal heat pump
I have an Aquacal heat pump, model number 110AHDSBTK. And I need a new control panel. I understand they have changed the panel to the new 4-button (ECS0276). My question is do I need to replace anything else such as the control board because of this upgrade?
Hello Jerry - I’ve reached out to an AquaCal tech. We’ll have an answer for you as soon as possible. Thank you for your patience.
Good Afternoon,
Hope you are doing well. My name is Robert & I handle tech support calls at AquaCal. The ECS0276 is all that you will need to replace. That part is perfectly compatible with your existing control board & will fit into the same area on your machine as the current control panel.
Thanks,
Robert Brown
