Since the beginning of non-swimming months, my PH has consistently been climbing. I’m adding 2-4 cups of acid weekly to keep it in check.
All other chems are find. Checked regularly at unmamed store and using my PoolGuru.
Any ideas on why my PH is always climbing?
We’d be glad to help you out. Is this a saltwater pool? What is the alkalinity level?
Yeah, I guess that would help. Fresh water pool.
Last pH 7.8
alk 94
cya 75
fac 3.9
tac 4.2
ch 229
tds 1000
pho 0
fe 0
cu 0
I put MA in regularly. Drops to 7.4 or .5 and steadily climbs by .1 daily.
One way pH can climb is aeration that is caused by waterfalls or a spillover. The alkalinity has an impact on the pH as well. Even though it isn’t super high at 95 ppm, it can still cause the pH to slowly rise. You could add enough acid so that the alkalinity drops to 80. Then see if that slows down the rise in pH. Some pool owners keep their alkalinity in the 60-70 range, so they don’t have to add so much acid.
With that being said, your pool water is technically balanced. Using the Langelier Saturation Index (LSI) is a great way to truly determine if the water needs any adjustment. I plugged your numbers in and used my pool temperature (65°F). The LSI reading was 0.02. Anything within the range of -0.3 and +0.3 is balanced. Here is a link to the calculator I use. https://www.pentairpool.com.au/128/Calculators/Saturation-Index-Calculator
Well, good news, pool is basically balanced.
Bad news, Ph still climbing daily.
I’ll try getting the alk down and see if that slows it.
Thsnks!
