Pool monitor indicates 00 salt. Has been working well for last year - have cleaned unit with no change. Is this a problem with the cell?
Hello StillMike - An errant salt reading is usually caused by the salt cell. The cell is what sends that information back to the control box.
My Compupool control unit keeps tripping the fuse. It will work for several days after I reset. Could it be the fuse is bad?
Hi 2306main,
By ”tripping the fuse” do you mean tripping the circuit breaker assigned to your CPCS. If so, you might try replacing that circuit breaker. They do fail. Also, make sure that your salt level is not too high. If the salt level in not within acceptable range, the cell will draw more current, run hotter, and might be tripping the breaker.
It’s not tripping the circuit breaker it’s the re-setable fuse on the bottom of the unit.
