I have an older compu pool cpsc 2400 which was giving the constant low salt and 69 water temp errors and was told to replace main circuit board. Ordered it from inyo pool resodered new board and found there was no place to put the fuse on it. Just to lugs for push on connectors. Is this the wrong board or do i have to do something to add the fuse?
Hello Kennyg,
We have a great How To Guide that may help answer your question. You can click on this provided link, How To Replace a Compupool CPSC LCD Printed Circuit Board, and it will take you right where you want to be. Thanks for the question!
Thats the wrong pcb there is nothing in the boards about the main power pcb that is the one i am replacing (part number JDPCBSCR)
Fuses were only used in the Compupool Power Packs prior to 2010. After 2010 the fuse was replace with a circuit breaker. The current replacement PCB boards will not have a place for a fuse.
Can you direct me to the appropiate circut breaker for this main pcb board i have the board installed but it wont work without it
Can it be purchased thru you or do i have to go through an electronics store any halp you can provide would be great thanks
