Century Vgreen Evo 165 pump not following schedule
just purchased a Century Vgreen evo 165 pump. I have the settings on the dip switch set to schedule B. I have run the schedule check mode and it shows at being on schedule 1.Here is a link to the video file. 20240901_132606.mp4 - Google Drive
I have it on a timer clock with the timer set to turn on at 8AM. Timer is set to turn off at midnight, which is past when the pump should be running. When I have checked it the last two days at noon the pump is not running at all. According to the schedule chart, it should be in the 2-6 hour bracket which it should be running at 2850 RPM. I have checked the motor itself and checked the outlets and there is no flow. Also my salt chlorinator shows no flow. But the pump is not running at all. If I press the button once, it goes into override mode and the pump starts running at full speed.
As a test, I set the Dip Swtiches to Schedule C. When I power on the motor, it runs at 1000RPM as it should. I was able to step thru the speeds without issues. I currently have it running at 2600RPM so I get constant filtering for now. But I want to fix the schedule issue. I have opened a ticket with Inyo but I have not heard back yet.
I have gone over the manual several times and I believe I have everything set correctly. Am I missing a step or something else?
Thank you
