I cannot locate where to order parts (gaskets and seals) for my Century Centurion Pool Pump. It is B2853V1. Model f56ab45z01. I have a leak from the underside where the pump meets the housing.
Any help with the correct replacement parts (and place to order) would be appreciated.
Hi Jeremy, the gaskets and tune-up kits are specific to the pump and not the motor - and the B2853V1 sounds like a motor model.
Let us know the model of the pump (or attach a picture of it and any labels on it) and we would be happy to point you in the direction of the perfect seals to stop the leak.
Ahh. That makes more sense. The pump is:
Perfect! Thank you for the picture.
Your Challenger CF-Series pump will use the GOKIT73 or, if you have a saltwater pool, you may want to get the heavier-duty GOKIT73SALT.
It looks like you may also want to get a new drain plug gasket or a new drain plug.
Be sure to review our guides on How To Replace a Pool Motor Shaft Seal and, even though you are not replacing the motor, How To Replace the Motor on Your Pool Pump for some helpful tips to ensure a leak-free result!
