I need to replace bearings in my Century Centurion Serial 33814CH, Part 0-164303-23 ,Frame M56J, 1.0 Hp. Are the BEARING, 203 (62032RS) correct for this pump?
Hello GregoryK - We’d be glad to assist you. Your Century 0-164303-23 is a B128 model. That motor would require two bearings. You would need one 203 bearing and one 304 bearing.
If you know the make and model of the pump side, we can recommend a seal kit.
It is a Hayward Pump Model SP2607x10 Serial 21120711003905007.
Thank you.
Greg
Hayward model SP2607X10 is a Super Pump. The seal kit for the Super Pump is GOKIT3. If you have salt water, go with GOKIT3SALT.
