Can You Achieve a Perfectly Clean Pool Without Chemicals?
Achieving a perfectly clean pool without chemicals is a common question among pool owners. While chemicals are often used to maintain water balance and prevent algae, pool vacuum cleaners can help reduce the need for them by removing debris and dirt efficiently. Robotic pool vacuums, for example, scrub the pool’s surface, clean the walls, and filter out contaminants, which can help maintain clearer water for longer. However, it’s important to note that while a pool vacuum cleaner is excellent for cleaning debris, maintaining water balance might still require some chemicals. How do you manage this balance in your pool care routine?
