I have no ohter information but really need to find replacement tracks, destroyed by nearby tree roots over the years. Not sure who made the pool and how old it is (around 10 Years is my guess).
Round 24Ft/4ft above ground-
Hi bkoriko,
Could you post an image showing your wall pattern, also can you find any part #'s embossed into the underside of the plastic top caps on the pool, these are the pieces that seperate the top rails.
I need replacement top tracks for a 24’ Round Vogue pool. Help me find these please. They are 52 5/8" on the outside. They look exactly like the above picture.
Shelley,
I ended up using these tracks. Though they are not exactlyt the same design as the original, they do work,
By the way this is the Sea Isle pool, at least that is what I’ve found out. Hope this helps.
https://mwpools.com/usa-sea-isle-pool-bottom-rail-aluminum-4875-long-3552
Looks like this isn’t available anymore. bkoriko, do you happen to know the measurements of the replacement you used?
