I live in a manufactured home in FL. My septic system is about 20 yds from when I’m putting my above ground pool. I want the all aluminum BC pool but seems they are all semi- inground pools. Any good aluminum pool out there that is completely above ground? Also, no one in central Florida sells Buster Crabbe pools. I can have it shipped, but I also need installation.
Hi, Holly2DCDOO. After doing a little research aluminum pool kit must be either partially or completely buried for stability reasons. I’m not aware of any good all aluminum above ground pool. Before purchasing the pool check with Buster Crabbe for installers or if it can be installed by you the homeowner. I would also recommend that you check with your city/county to find out if a permit is required for a pool.
