Broken tip of skimmer gizmo
When I removed the gizmo off on my skimmer, the tip broke and leave about 1 1/2 in of the tip in the skimmer. I need an extractor to get that tip out. Would you by any chance have an idea where I can get one? Do you have other idea how to removed the left over gizmo threaded tip from the skimmer?
Would you be able to use a dremel tool and cut a slit in the gizmo? This would enable you to use a flathead screwdriver and unscrew the gizmo.
I have to drain the water from the skimmer to do that. I will just try to cut it with an hack saw blade.
Good luck! Let us know if that works for you.
