I was just given a 33 foot pool, pool seems to be in great shape but for 3 of the bottom rails,they are made of aluminum and had rotted away,they measure 49.75 on the curb, 49.25 on the straight measure,they are 1 inch wide and 11/16 tall with a slot opening in the middle,does anyone know where to get these parts,I do not know the name of the pool
Hi Ronald,
Could you post a few photos of your pool to this thread.
- One which is a wide shot of the pool showing the wall pattern
- A close up shot of the top cap
- A close up shot of the top plate
- A close up shot of the top rail
Also, can you find any part #'s embossed into the pvc top caps and metal top? Many times the part # is on the underside of the top cap. All this information will help us find the correct replacement parts for you.
We have been given an above ground pool We were told it was 18ft round- but that is not correct. We were unable to measure prior to dismantling due to the poor condition that it was left in. We need replacement bottom rails, The rails are 55 5/8" long, 5/8" wide and when stood on a flat surface the highest point is 3" tall. There are 18 rails. We do not know the brand of the pool.
Hello Ige2617 - We’d be glad to assist you. Could you post the following pool images?
- Outside Pool Wall (Top to Bottom)
- Top Rail
- Top Cap
- Bottom Rail
InYo Pools,
I was given an above ground swimming pool and I’m looking to replace the Bottom Rails for a 24’ round pool. I do not have the brand name nor model numbers. Can you help me find the replacement parts I need? Age of the pool is over 15 years.The bottom rails mesurements are Lenght is 55" bottom size, 55 1/4" Top (open slot) side, 1/2" width by 1/2" tall. Need enough pieces to replace all bottom rails. When we took it down it was 15 pieces. Numbers on the inside of other pools parts 6774. Please help. Thanks! Connie
Hello ConnieOlah - We’d be glad to assist you. Could you post the following pool images?
- Top Rail
- Top Cap
- Bottom Rail
Rob,
Do you have an email so I can sent my images?
Connie
