I have an Intermatic pool motor timer. The timer itself is not getting power to operate. This is a 110v unit. Can you tell me the part that supplies power to the timer?
If you can still turn the equipment on manually from the timer, you may need a new clock motor. The most common timer motor for an Intermatic T101 (110v) is part number WG1570-10D (WG1570-5). You can verify the motor part number by pulling the mechanism out of the box and by looking for a number on the timer motor.
If you can’t turn the equipment on manually from the timer and you’ve confirmed that the timer is not receiving power, there is an issue with the source of the power. Check the breaker to make sure it hasn’t tripped. From there, I’d recommend contacting an electrician.
Thank you for the information, however, my Intermatic PF-1102 does not have that type
Thank you for your reply, but as you can see, my Intermatic timer does not have thay type of clock motor. I’ve include pics of the model #, the front side of the timer and the backside of those components. I’m not sure what that component is that’s positioned below the timer, but it seems to act as an interface between incoming power and power to the timer. I’m thinking that my be my issue as I’ve replace the old timer with a new one and I have the same issue…the timer won’t advance. Again, thank you for taking the time to review my post.
The model number and info on the box indicate that it is the 240v Intermatic PF1102T timer. Your original message stated that the timer was 110v.
I’ll assume it is the 240v model based on what I see in the picture. If power is making it to the timer box but not making it to the timer mechanism, the issue could be the relay. The part number for the 240v relay is 143T135.
Thank you for the reply. That is exactly the part I’m need, but in 110v. Do you have the part number for that one? Thanks again
The part number for the 110v is 143T136.
Thank you for all your help. I’ve got the part ordered.
Again, thanks
You’re welcome!
