I have an AO Smith motor (B855, 2 HP, 56Y frame, SN 281073M). Do you have the correct bearings for this motor?
Hello MarkBa - The AO Smith B855 would require (1) 304 bearing and (1) 203 bearing.
Let us know if you need any additional assistance. Thank you for shopping with INYOpools.com!
Hi MarkBa,
We also have a Video on How to Replace Pool Motor Bearings which you may find helpful.
The motor I have now is 8 years old. I am starting to think, I would rather put $50 towards a new motor instead of bearings.
I will go with an AO Smith B855 again. Which gasket kit should I buy for this? The pump is a WhisperFlow WF-28.
The gasket kit for the Pentair Whisperflo would be GOKIT32 for regular water or GOKIT32SALT for salt pools.
The kits include the following:
- Shaft Seal
- Impeller O-Ring
- Seal Plate O-ring
- Diffuser O-ring
- Lubricant
Mark,
I would agree for the additional money I think it would be worth getting a brand new motor, not to mention the installation of a new motor is way easier than the process of replacing the bearings on an old motor. Here is our Video on How to Replace a Pool Motor which you may find helpful.
