I need new bearings fro Century Motor 7-196018-01 (photo of tag attached), please advise what I need to order. Are there any other parts I should renew when installing new bearings?
Thank you for shopping with Inyo. Your motor, 7-196018-01 (B2235), would require two 6203 bearings.
When installing the new bearings, you’d probably want to install a new shaft seal. We’d have to know the make and model of the wet end in order to recommend the correct shaft seal.
