Hello
I need to replace bearings on my pump motor and would like to have them on-hand prior to dismantling.
Can someone please help identify the required bearing sizes.
Hayward Tristar sp3205z1BE motor made by AO Smith p/n 7-196341
Thanks!
The Hayward Tristar SP3205Z1BE motor made by AO Smith, part number 7-196341, requires two bearings. One is a radial ball bearing, and the other is a thrust bearing.The radial ball bearing you need is a 6203 bearing. This bearing has a bore diameter of 17 mm, an outer diameter of 40 mm, and a width of 12 mm. You will need to purchase a bearing with a double seal to protect against moisture and dirt.
The thrust bearing you need is a 6205 bearing. This bearing has a bore diameter of 25 mm, an outer diameter of 52 mm, and a width of 15 mm. You will also need to purchase a bearing with a double seal to protect against moisture and dirt.
It’s important to ensure that you purchase high-quality bearings from a reputable supplier to ensure reliable performance and longevity. Good luck with your repair!
