Bearing replacement for Century HSQ165
I have a Century HSQ165 that is screaming like a banshee. Time for new bearings.
Can you tell me which bearings I need for this old boy?
I think my pump is either Sta-Rite Dura-Glas or Max-E-Glas (if there is a difference) I’d like to do whatever tune up it might need at the same time as the shaft seal.
We do not have a parts list for the HSQ1152. You’ll have to pull the bearings from the motor and look for a part number. There should be one on the bearings.
The tune-up kit is part number GOKIT54. It will work on models manufactured since 1998. It will work on older models if you remove the copper cone from the seal plate before installing the shaft seal.
My motor is not “HSQ1152”  it is HSQ165.
You carry the HSQ165 as a full motor Century (A.O. Smith) 1.65 HP Up Rate Motor, Square Flange 48Y Frame, Single Speed - Model HSQ165 - INYOPools.com
I found a Centurion-PRO Spec Sheet that lists
Centurion PRO Stock Number: HSQ165
Century Cross-Reference: SQ1102 and USQ1152
You guys have a USQ1152 break down
It lists Bearing, 203 (Single) - 62032RS
Part # 5270-31
Manufacturer Code: 6203
BUT … There is a A&Q that points to a different bearing.
"Asked on 10/25/2016 by Mike P
I have a Century HSQ165 1.65HP motor C48AB46A01. What are the proper bearings for this model? Thank you for your time.
 Reply
A  Answered on 10/26/2016 by InyoPools Product Specialist Lennox H.
Hi, Mike. The HSQ165 motor uses the 304 Bearing according to the Century Pro Spec Sheet."
What is right?
