Looking to link in my older Aqua-Logic PS4 (new control board installed this year - so should be latest revision), into the home automation system and/or control remotely. Reading, it appears that the AquaRite Omni PCB Kit will link to the PS4 and allow the connection. Is this correct? Anything else I may need?
On our pool, the PS4 controls pump (single stage), heater, pool slide valve, pool lights, salt system.
The AquaLogic PS4 will only interface with AquaConnect # AQ-CO-HOMENET if the AquaLogic has been upgraded using a ProLogic main board # GLX-PCB-PRO. In addition, to interface AquaConnect with home automation systems it will require with AquaConnect Serial Interface # AQ-CO-SERIAL. With the unit upgraded appropriately and these interfaces, a control is then compatible with home automation platforms manufactured by Crestron, AMX, Savant, and Vantage.
