I have just installed a variable speed pump but at low rpm (1300 -1400) I get an indication that there is no flow even though water is circulating. At higher rpm’s (approx. 1700) the no- flow indication goes away. Is there a minimum rpm necessary for the flow indicator to indicate there is flow?
Charlie - We’d be glad to assist you. The Aquarite system requires a minimum flow rate of 11 gallons per minute. They do not list a required rpm because every pump and pool is different. There are too many variable to list a minimum rpm. You’ll need to experiment with your pump and see what works.
Thanks. I should have know that but you answered what I wanted.
We’re glad we could help answer your question. Let us know if you need any further assistance.
