Hello,
The Problem: the Jandy PDA barely works. A buttons don’t always respond when pushed, register two presses when keyed once, most be keyed several times to respond, etc. Basically, the PDA is sketchy. So trying the set a new program is impossible. Just turning the pool light is a 5 minute battle with the PDA.
The rest of the equipment and the main Aqualink RS control panel seem to work fine.
What is your suggestion for new equipment? I don’t want to order a new PDA if 1: the PDA isn’t the problem. 2: the next PDA will go bad. 3: for the same amount of money I could get an iPhone controlled system?
The Aqualink RS is about 10 years old.
